OK a question for the increasing financial planning folk
Mate is in a very bad situation
Bank is repoing his car next week
Apparently house soon
So I'm trying to sort him out with a job at work
However we do a financial check lucky only a simple one for sales
Will this come up as a bankruptcy or is he ok
Cheers
No shouldn't show as bankrupt as he hasn't declared it or been forced into it - yet. Credit history might not be too flash though I guess?
if he wants to save his house he should get it on the market and go talk to bank if they take it by the time they add fees etc he won't see one cent.
You can't be bankrupted over a secured debt until after a shortfall has been crystallised. So if he still has the house / car then no he won't be bankrupted.
Unless it was over a secured debt and the bank is taking the car/house on behalf of a bankruptcy trustee.
First scenario is more likely if he hasn't told you he has been bankrupted. Trust me, you know when this happens.
I would however assume he has unsecured debt like credit cards that he has probably been creditlisted for.
If there is a shortfall after the house is gone and he can't negotiate an arrangement and doesn't have LMI, and the shortfall is worth the expense of suing him, THEN he can be force bankrupted
Haha yup.
Am posting this from the Singapore airlines business lounge travelling to a 20 day Europe trip on only 1 week out of my 6 weeks annual leave.
#fifolyf
Send me your itinerary, could catch up.
For now though, I'm going shopping on the Champs Elysees
OK cool thanks for that
Looks like can try help him out in shot term
That said anyone looking for a fairly clean 8mr keep an eye on auctions
anymore jerbs you can hook me up with?
my stuff wont be repo-ed but would be nice to be full time.
so an old mate of mine is in the Bentley club (not rich, he owns a peice of shit 80's Turbo R) and they just did a day at DECA.
They used the back track and I highly doubt they made them get CAMS licenses
So fkn typical of motorsport in this country... there is 1 set of rules for Jap cars, and 1 set of rules for everyone else :/
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
