I have the money to lend you Simon but they are frozen assets that you and only you can access and I would need your assistance in transferring them via the Solomon Islands
Just putting it out there, Faythe is probably the worst name in the world that you could give someone.
Not only is it unoriginally hipster that you want to swap the i for a y, but you add an unnecessary and pretentious e on the end, then just the whole concept of naming your child after a belief system in the first place. It's like a multi-level troll and I hate it.
hipster?
more like straight bogan
Every paddock from chirnside park to eildon covered in frost. Bit nippy.
Apparently they closed down mt donna buang over the weekend cause so many people rocked up. 2hr queue up the mountain. Warburton was a carpark.
Yup, they sure did!
Also closed road up to Mt Macedon for about 48 hours as too many were going up & was getting dangerous
i know of one tuner whos notorious for bad cold starts on eth.....
so might not be plugs dude.....
There is no such thing as a perfect start on a cold melbourne day on e85.
really its
1) Does the car ACTUALLY start in under 30 seconds (maybe multiple tries, couple stalls, etc)
if yes: Your car is fine, get over it
if no: Something is probably up
I reckon people saying "lolz cold start on e85 is bad" is because they have an aneurysm if the car cranks more than once.
Source - f**ked with cold starts on e85 for literally multiple hours a day over two weeks, ended up raging at fuel pump.
anymore jerbs you can hook me up with?
my stuff wont be repo-ed but would be nice to be full time.
send me resume.
only draw back in only area that might be hiring ATM, is full of Asian females..so you might have to get daddy to buy you a brand name bag to fit it.
send me resume.
I have a Bally and also a prada, which is more suitable?
and you has pm. if resume sucks, tell me too.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
