Your qualification/experience gets you through the resume stage. Your character/personality gets you through the interview stage.
Don't mix up arrogance/"I've got this job easy" with confidence/charm
Yup + 1
I'm also doing interviews at my firm at the moment. If its for a grad position, it would just be how the present themselves & personality. If they seem they will be a good worker
  • Like 1
So, whos the go-to guy for re-assembling an engine with a minimum amount of fuss, quick turnaround and/or a minimum amount of utter bullshit?
Is there even anyone anymore?
http://www.head-spec.com.au/
if motor is already out, turn around is good.
also Moh had good experience with http://engineaction.com/
It's currently still all in the car, and I'm not on speaking terms with it right now.
The head did get ported and polished, then it exploded, then "fixed" and now I suspect it exploded again simply due to the fact that my entire radiators contents appears to have exited through the exhaust.
So that's nice.
Last time (can't believe I'm typing this really) the bottom end turned out to be completely straight. Really hoping it'd be a case of "put a standard head on" and move the cams from the dead one to the new standard one.
However things typically rarely go as planned and/or end up being best case scenario so I'm sure it will cost $100,000 and take approximately seventeen years to get running again.
  • Like 1
So that's nice.
+ 1
If you need assistance send me a PM and i'll see if a cash job can be done
Originally, this happened:
This was apparently fixed.
I suspect it's become un-fixed.
It's entirely possible it's not that, and an entirely different cylinder, or gasket, etc. All I can go on is that it behaved itself perfectly on the dyno, so no one really suspected a thing.
Can't really know what damage has been done till it's all pulled apart, the bottom end may not have survived the second time.
That said, the second death was certainly less explosive than the first, which was a good ol fashioned hard stall at 7000 RPM at undisclosed speed.
me and hard stall is this
crossed-fingers-sign-of-the-cross-resemb
but i feel for ya. but there comes a time in any nissan owners life when they have to decide how they want to build a motor... go all out and spend big $$ to get back what you once had, or to go mild where its less risky but also boring (and it will probably still go bang anyway)
I tried that, but it exploded before it left the dyno (before I took receipt of the engine that was put in to do just that)
So I got it forged and stroked to 2.8-9L via Mr Brian Crower.
It did not hard stall the 2nd time. It'll actually start and run on what seems to be 5 cylinders, but yeah obviously I'm not wanting to press my luck by continuing to do that.
last time at winton you took advice to just pull out a bit of timing from your engine, you went back out and barely made it back to the pits...
motor went esploded, taking the bottom end with it.
Can't wait for the weekend, going to pull apart this evo and start making lists of things I want to repair / replace / remove / de-rust.
I get the feeling like it's going to be a decent list :|
Yay new projects!
Saturday morning getting an eye test done at the optometrist, with eye drops... going to have pinger eyes for a few hours so I hope its not too sunny and I'll still be able to drive home without dying :P
Stare into my eyes... yes, yes... let the soul flow through you.
lol @ pinger eyes. get pulled into booze bus... theres a few hours of your work time gone.
at winton motor was going to esplode anyway from the sounds of it. should have just called it a day or not even gone lol
If I hit a booze bus in 1.5km of Vermont South back streets at Midday on a Saturday, I'd be very surprised.
That said, I've seen one a few times on Terrara road next to the footy oval on a Sunday Morning, in a very visible location that you can avoid if you were still a bit over from the previous night... So a pretty pointless spot if they were trying to get the tards off the road.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
