Have heard people just whack an eBay manifold on the Ford 4L and a GT35 and run low boost no problems
Would be pretty funny to try with an old piece of shit
Hmmmmmm intradesting I have my grandfathers old el sitting in our paddock :P
they do motorbike and misc. machinery... its all about getting parts really.
after speaking to our mutual friend yesterday, i dont think he's too keen on cashy's at the moment. the workshop will take em though.
after seeing the motor yesterday, needs a replacement crank :angry: (good thing i didnt go stroker kit)
dude... it took you 2 years to change a set of rims
that's cos it's my own car. Plus all monies went to buying apartment instead of unnecessary mods.
Well he builds all sorts of engines
He probably rebuilds an engine a day, not just high performance, lots of insurance ones. So i'd say he's dealt with a wide variety
so does he need engine out or does he engine out, rebuild and reinsert? The less car I need to work with the better. How does this work, do you have to put in an intro or do I just call him and be all like "Tony said deal with it"
Correct
Cash job just means you get paid for the service in cash. Amiright?
But is it tax deductable?
On a side note, I do have an accountant friend with a few years exp that might be interested. He just got married and is on honeymoon atm though...
unnecessary mods like fucking what? a pair of cashmere wheel changing gloves?
  • Like 1
He can do it all *if* he isn't busy
Best to just shoot him a PM, just say your from SAU and Tony told you to contact him through it
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
