Need wasteland guidance...
Had a set of AVG Model 6 in Silver (Staggered 17x8/9) on the skyline when I bought it, just bought an identical set in White (Staggered 17x8/9) since 4wd diffs hate stagger
Will sell the 17x8 set and run the 17x9's on the emo.
What colour should I respray them? Currently leaning towards the white...
Thoughts?
alienware is all aimed at gamers yes? Can't see myself every using it for gaming, but I'll look at the range and see if anything takes my fancy...Will hit you up for discounts if go down that path...
The price on the Dell site for the XPS15 I linked above says including 20 or 30% off, do you get a further 10% off that price or only off the retail?
Leigh, had never heard of MSI til yesterday when I looked on scorptec/centercom... they're aimed at gamers too I gather..?
Unfortunately not, only 10% off retail.
10. Coupon discounts cannot be combined with any other sale, discount, promotion or coupon.
Thoughts?
First everyday of the week... Or black
Where dem valve caps at?
You want em?
15-inch MacBook Pro with Retina display
15-inch: 2.5GHz
with Retina display Specifications
  • 2.5GHz quad-core Intel Core i7
  • Turbo Boost up to 3.7GHz
  • 16GB 1600MHz memory
  • 512GB PCIe-based flash storage 1
  • Intel Iris Pro Graphics
  • NVIDIA GeForce GT 750M with 2GB GDDR5 memory
  • Built-in battery (8 hours)2
  • Available to ship:
    Within 24 hours
  • Free Shipping
  • A$2,999.00
ZOMG Free Shipping!!!!
Not white. A colour dark enough so you can put illest stickers on each spoke.
Do the 9's fit ok? No poke? 245's?
so funny lel... you can get illest stickers in dark colurs...
troll fail
Also go satin black Simon... as martin said it looks tits teamed up with some carbon.
you can even get a boss result from rattle canning it in that colour if you are careful
Possibly the most hipster thing I've ever had the displeasure of skimming through.
Referring to Glen Iris as a leafy suburb wtf
Micro herbs and paleo pancakes, go fk yourself
  • Like 1
Fk i hate this "paleo" craze
I hope research in like 5 years time shows it causes ass cancer
it already has albeit indirectly, from all the foodie wankers ass f**king each other over it.
loving this, a store that really understands their guests
"Prior to their departure, visitors to AK Duty Free can relax at the AK Lounge, enjoy a cup of espresso, and sample our wide selection of top brand-name cosmetics. In addition, we have a “Shopping Manager” standing by at all times to assist our male customers, and we provide personalized product shopping information, a highly popular service with our clientele."
Duty Free in Seoul airport,
So you give the wife's list of cosmetics she wants, and they go grab it all whilst you have a coffee and your done..
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
