Possibly the most hipster thing I've ever had the displeasure of skimming through.
Referring to Glen Iris as a leafy suburb wtf
Micro herbs and paleo pancakes, go fk yourself
nah bro, ignore the paleo stuff. (had to look up what paleo was... sounds like polio)
anything with chorizo or hash browns. maybe some of the stuff with buttermilk
melbourne-best-breakfast-you-may-not-hav
also, whats with all those STI liberty owners going on about there only being 300 available? theres like 3-4 pages of them on carsales. 300 in Aus is surprisingly not that rare. alacantra seats would be lucky to last 100,000kms.
I don't know shit about processors etc but the both are quad core i7... Asus is i7-4710HQ, Dell is i7-4712HQ - guessing 12 is better than 10..?
Actually the opposite...
The 4710HQ has a faster clock speed than the 4712HQ (6% faster)
The 4710HQ also uses more power (20% more)
http://www.cpu-world.com/Compare/1/Intel_Core_i7_Mobile_i7-4710HQ_vs_Intel_Core_i7_Mobile_i7-4712HQ.html
Edit: As it's in a laptop, aim for the more efficient cpu with less power consumption (the 4712HQ in the Dell)
A desktop doesn't really suit my situation though... hence the desire to purchase another laptop
buy a 15" that's got a gtx video card and 1080p, spec it with a butt load of RAMs and SSD, and buy a docking station and a nice big monitor, keyboard n mouse.
Yeah docking stations are the bomb, only problem is you are limited and have to buy a laptop with the 'docking port' under it. (Dell latitudes etc) would be awesome for a home desktop/laptop solution though.
Like this, then chuck a Dell monitor on, attach a keyboard and mouse to dock, done.
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=330-0874
I agree I wouldn't go over 15" or be a pain in the ass to move around
Edited by UNR33L
Forgetting all of this docking business as it's highly unlikely I'll ever do it... Which of the dell/Asus I posted before would you buy? Exact same price with slightly differing specs..
Or any other options around that price?
And pretty sure my current one is 17" and I can't say I've ever had trouble moving it around.. Harden up kunce
Anyone who complains about carrying around a 17 inch laptop needs to lift more
What are you constantly in a marathon
How I picture dezz...
10745383-businessman-with-phone-and-lapt
except more dodgy looking.
I wouldn't go that dell, 4k screens on a laptop just look stupid at native res and you have to use the shitty windows scaling.. which looks sheit. aka, icons for ants.
I'd go one of the MSIs linked above > Asus > Dell
Edited by UNR33L
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
