Yeah the second one sounds more like what I want... Can't see the value of the properties going up that dramatically any time soon.
What's the go with the 5 year stuff, buying a house withn 5 years old etc, for claiming depreciation or whatever...if you buy a 4 year old house, does that mean you only get a year of whatever that claim is...
Tax depreciation report, claiming depreciation on building and fittings, nothing to do with 5 years. Though you get bigger advantages on new property
Or you buy an old property, Reno it with your tradie contacts & either flip it or rent. If you flip it you will have to pay 40% tax on the profit else just rent it for a larger sum which puts it close to the mortgage repayment.
40% tax a fairly specific set number :P
I didn't really have a budget, but wasn't going to spend $5k on a laptop when I'm not even gonna use it for what it can do (gaming)
But I don't like buying inferior products either, so I said a number to give you guys a range to work within..
I got it for $2550 from centercom in the end... scorptec wouldn't go below the ticket price of $2649, online stores I could've got it for $2400-$2450 but I wanted to buy it in store..
noice.
the 3k model has been reported to heat up a bit when pushed to limits while gaming, but you shouldn't run into that issue.
lol @ the block first world problems ... My owners would be doing back flips to get 10k, 40k over reserve! Shit even to get reserve!
I don't watch the show but I'm reading that the issue is the contestants doing all the work for 6 months? and only getting $10k as a couple
Though some got $300k plus
It's a reality show....
Their regular income would have been paid by the network in addition to the $10k, just like on masterchef etc... It's a GAMEshow... not everybody gets to win. Big Whoop... Harden up
Their sooking is unwarranted and annoying
  • Like 1
Didn't wanna bother you with work related questions lol...So basically newer the better...? Any other specific things I need to avoid/aim for?
noice.
I'll try to keep it well ventilated when watching high def porn
  • Like 1
My advice would be if its an investment property, move in for 6 - 12 months. Move out and go back to your rental for ~6 years
That way when you sell its Tax free in relation the capital gains
Disclaimer: This is not advice you should speak to your qualified accountant
  • Like 1
With so many people trying/doing exactly the same thing (buy, rent out, negative gear, buy again) where will the market go? The rental market is flooded with houses at the moment, a lot of them overpriced because people need the money to pay off the mortgage.
If rent is so much cheaper in the CBD than the burbs, i think rental prices are going to spread from the cbd outwards and shrink purely because there are so many investment properties & town houses popping up. Especially when a lot of older folks are trying desperately to make up for their lack of super. That plus foreign money snapping up properties... Somethings gotta give in the next few years.
+1
Every dual income couple is jumping on the investment property wagon cause all their friends are doing it.
If you not willing to renovate, or move into it & your only advantage is an income, you are no different & will be competing with the same herd of sheep.
  • Like 1
Yeh however they get $700 per person per week to cover expenses so hamish hit nail on the head they act entitled but it is what it is suck it up
lol @ fanboism
lol @ gtr circle jerking
lol @ angry seller telling market what his item is worth, calling them cashless deadbeats and then desperately lowering his price later on to below offers previously rejected
http://www.sau.com.au/forums/topic/438621-genuine-rays-engineering-nismo-lmgt4s-18-x-95-12-offset/
  • Like 2
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
