Getting adjustable rear camber arms installed, anyone know how much centreline suspension charges for wheel alignment and adjustment of camber arms?
Or any recommendation of places for wheel alignment?
Am so sick of this negative camber tyre wear!
#stancelyf4homo
Ask centreline how much they're gonna charge you the second time when you go there for something else and they tell you that your suspension set up is way out and asks you who did it.....he wasn't happy when I told him he set it up.... Or at least charged me a ridiculous amount and claimed to have done so
ôoooooh. tis a flamin mongrel when that happens. well within your rights to tell them to reverse it, as you didnt authorise the work.
edit* may or may not be within your rights in australia......
I went to Centreline a couple of times.
Service was excellent, suspension setup was perfect and he didn't charge me for any of the work in finding the fault.... only for the setup, install and parts.
Couldn't have been happier
What if he'd given you a wristy at the end? Note this did not happen to me
do rate centreline. after getting an alignment at a standard tyre/suspension shop and receiving the figures, then going to centreline to have it double checked cause it was weird... centreline showed me there was nothing wrong. and they said some places dont calibrate their alignment gear as often as they should.
Chris is a good guy, they know their stuff. You dont go there expecting a cheap bill but provide quality work and really good feedback on setups. Will be taking the gloria there to get the suspension sussed out fo sho.
Centreline did $1500 of suspension work for me, which I'm pretty sure was quoted to be around $1000. When I went to pay I asked about the SAU Vic club discount and he said that I should have told him upfront about that (so he could budget for it?), that the time they spent on my car was more than he charged for and that they always look after anyone with a Skyline anyway.
They did good work I think, but too far to travel and don't fancy those bills. I go to Traction Tyres now. Had a reasonably priced alignment there and the guy who worked on my car spent 10 minutes explaining what he did with it, why he did it and the limitations of my suspension setup etc.
  • Like 2
holy shit did we just agree on something?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
