It isn't one of those fancy laptops with a 3g card in it?
As in, not actually on your wifi?
When I log in to my router it shows the new laptop as connecting via Ethernet.... Everything else (other laptop /phone) are connected via wireless...
Inb4 VWL internet speed test screenshot pissing contest
truest truth ever trued
f**k that is tempting....
If it was manual.......... I might think about a chaser next... have wanted one for ages
Why the f**k does everyone that posts masallah insallah meibruk or whatever the f**k you're saying, only say that one word in arabic and the rest of the sentence in English?
inshallah = god willing
mashalah= thank god (loose translation)
mabrouk= congratulations
manyook= cock sucker
ayr= cock
jahash= dez
hmar= dez
ayer bi teezak = platts favorite phrase.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
