what's the actual name of the wireless adapter? like if you go into device manager > network adapters, i'd start by getting the name of it and googling to see if anyone else has had the same issue.
I had a problem with my wired ethernet recently.. one particular driver version wouldn't let me run an online application and was a known issue after a quick google.
well the networking stack and such is fine as it works on ethernet, so odds are a drivers issue.
when connected to Ethernet, go into device manager delete the wifi drivers.
go to the manufacture site and download current one.
install
hope for best.
(I am assuming you have rebooted......)
damn feels like I'm bigpond support again..
Kunce got a speeding fine after they took my car. Not sure if I want to look at the photo or not to see their f**kin ugly mugs in my baby
How quick and what location?
Also yes, obtain and post photo.
  • Like 1
AC 7260
I googled it while trying to fix it and it's obviously a VERY common problem to the point where msi are literally robbing people for the money they're charging for it.
How can a f**king high end gaming laptop have such bad wifi
The thing is f**kin useless to me now
70 in a 60 zone.
Preston of course, directly on the way from Hawthorn to Mill Park
Mill park is where that dude had the white s2 part's with new headlights, did you look into him?
That was Lilydale or Kilsyth or some shit. Didn't bother.
Dezz, you free next week Monica? Could belt the kunce over the head with your new laptop
Edited by HEKT1K
  • Like 1
yeh, the dude lived in kylsyth but in the background of one of the photo's there was a deleted add that had the items advertised as being in mill park. (he took a screen grab)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
