Martin best way to get Malaysian ringitt over there at an exchange booth? from a quick google this seems to be the suggested route..
Applied for my 28 degrees card a bit late :\
Edited by UNR33L
yeah booths are best, in back-packer areas even better
and the more you convert the better the rate/fees
at least as a rule.
never convert at Melb airport, or AU banks!
Sweet, I'll just take some aussie dollars with me then
+1 for don't convert at Melb airport
I gave them $10 SGD and I'm pretty sure I ended up with a couple of $2 coins after their transaction fee and god awful exchange rate. Should have kept the money lol
I did the exact same thing! Only because I had make a phone call, luckily the missus picked up her phone because I could only afford a single phone call after the conversion.
lol when I was in NYC with some mates we were walking near Central Park and this absolutely gorgeous girl with a sexy eastern european accent ask us if we wanted to hire bikes for a couple of hours to ride around the park. So of course we were all like "yes ma'aam"...
Nek minit we're in an alley with 4 huge adidas tracksuit wearing mother fùckers straight out of the movie Hostel, getting rusted shïtter bikes out of the back of a van... for $10/hour, with a $30 security deposit that we didn't expect to see again, and a $10/15min overusage fee.... Didn't help that they'd moved the van when we came back an hour and a half later...
Still, point of the story was the girl was hot.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
