Corollas are shit unless we're talking the 90s fwd model that actually looked and went alright
only Factory ADM corolla I would own was the E110 95-01
specifically this model:
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-3051415&Cr=0
note did say factory ADM....
Fyp brah :P
This is true.
Solve ecu options first, see what exhaust/injectors/intake/pump do... Then turbo (which will probably mean end of cvt)
But i dunno if you can even properly dyno a cvt?? Obviously you can see tps, velocity, afr, psi, so you could make it healthy but getting a 1:1 ration would be hard. You can force it into "gears" but who know what ratio they would be if its variable.
Are we still stirring up Hamish? I just saw a mad DJ driving on church st in a 911..... John Course
So refreshing to see a DJ who sticks to his roots and is all about the music
Do you remember the time we saw him play at CQ on a Friday, and then outside the club in his car? That's how I knew it was him just now lol
Nah my memory of CQ days is hazy at best - did we go specifically to see him as a guest DJ or was he regular there?
I do remember skipping a line of like 200 people once, that was grand
Na I hit up some soft shell tacos from salsas... Should have got the spicy ones, the plain beef needs a bit more kick...
Would totally demolish that burger over a few hours though... Apparently to get it, I'd need to fly to Chihuahua Mexico, so its a bit out of my price range.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
