Corollas are shit unless we're talking the 90s fwd model that actually looked and went alright
only Factory ADM corolla I would own was the E110 95-01
specifically this model:
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-3051415&Cr=0
note did say factory ADM....
Fyp brah :P
This is true.
Solve ecu options first, see what exhaust/injectors/intake/pump do... Then turbo (which will probably mean end of cvt)
But i dunno if you can even properly dyno a cvt?? Obviously you can see tps, velocity, afr, psi, so you could make it healthy but getting a 1:1 ration would be hard. You can force it into "gears" but who know what ratio they would be if its variable.
Are we still stirring up Hamish? I just saw a mad DJ driving on church st in a 911..... John Course
So refreshing to see a DJ who sticks to his roots and is all about the music
Do you remember the time we saw him play at CQ on a Friday, and then outside the club in his car? That's how I knew it was him just now lol
Nah my memory of CQ days is hazy at best - did we go specifically to see him as a guest DJ or was he regular there?
I do remember skipping a line of like 200 people once, that was grand
Na I hit up some soft shell tacos from salsas... Should have got the spicy ones, the plain beef needs a bit more kick...
Would totally demolish that burger over a few hours though... Apparently to get it, I'd need to fly to Chihuahua Mexico, so its a bit out of my price range.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
