Prior to getting the club plates the car hadn't been driven on the streets for the last 5 years so I wouldn't really know. I've only ever had full reg on the street for about 6 months.
I got pulled over once a couple of months ago just so they could hassle me and check my log book, everything was good though so I went on my way.
Can't have R34 on H plates until 2023
Wasn't asking in regards to my R34
So in reality your post is actually too soon junior
Mmm things might change with the new rules changes re club reg
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
