IIRC, that was during the fuel/energy crisis when severe emissions regulations were brought in - everything was hardcore detuned/restricted because that was the most cost effective way to meet the regulations. They also put a bunch of small engines in their large cars. If you look at American engines of similar size from the 60s, or late 70s, the power is a very different story!
Nonetheless, torque was more important than power from these engines as they were coupled with tall gears/diffs and even with limited power the bigger engines still pulled respectable quarter mile times. It also didn't stop people from modifying them to remove the restrictive nature of the engine.
I just find it surprising the most common (and successful) motors at world time attack are 20 years old lol
As much as i wish people could manipulate and change modern engines the same way people do 90's engines... Its just not heading that way. Even if there was a large customer base, theyre getting harder to crack.
The only real modern engine i can think of that still gets massive modification treatment is the LS series, but the base motor has been around for ages
Actually I don;t think it due to not being able to tune the egine, look at the R35 for example.
I think a fair bit of it how heavy the cars ended up getting.
now that they are looking at efficient cars getting lighter again so I think the next generation will be looked at for TA again.
but think about getting around a corner,
Evo 8 is 1320 kg,
R35 1740
S15 1200
with a limit to the weight reduction based on a % factor you still end up with a very heavy car and weight is the bane of racing.
What kind of engines are you talking about?
RB's, SR's and 4G63's?
These days when its all about cost cutting efficiency, fuel economy and emissions, there's hardly any Over-Engineering which allows you to make 2-3x standard power on an engine, simply by adding boltons...
^exactly...? Over-engineering is certainly cost cutting from a tuning perspective, but look at subaru... Many parts are like glass but theres demand and therefore solid replacements. Just most of the base motors are still over 20years old lol.
But theres no V8's, and few 6-cylinders even. Rotories are really only still in the picture because their fans are purists
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
