On the rhs of the site in the breakdown cost, it says compliance $5k yet down in the overview tab it states "Cannot be Complied. Race use or display purposes only" ??
So in the end Beer was 8.80 for a pint of full strenght, so pub pricing game was too quick to make much use of it tho.
more to the point considering general admittance is 50+ for 2.5 hours of sport, not good value
glad I did not pay
Lol and a magical $5k for compliance plus import fee.... Amazingly every other car compliance is cheaper. I met the dude earlier today and I don't think he makes too much money
Why would he, that site looks like the biggest rip off. Nothing special about the cars and local equivalents that you can test drive are cheaper lol
That RX7 was a joke
anybody feel like doing some fast-ing for me? ill give you some beer,
B8204C9914 - remote
F2310AG152 - grille
The difference between these floor mats: G4900CR121, G4900CR120, G4900CR111 (G4911CR111, G4911CR120, G4911CR121) J or G interior ??
G9700AG000 - rear sunshade ?
YA76400001 - whats an auto keeper?
Birds' Tales of Chop: Volume 8: Golf GTI
Pulled away from him in a couple of rollings; he kept up surprisingly well for a Golf. Pulls up next to me; car full of young wogs saying "cool car man". He might have equalised without his passengers. Turns out this thing had NOS...dafuq? Wow, so fast. Much furious. I need two of the big ones.
See you all next time.
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
