3" fujitsubo legalis.
im wrapt with the power though.
My 3inch wasn't even a 1kw restriction when we tested at 320-330rwkw on 98 octane.
And wasn't a restirction at 380rwkw on E85
Just sayin
  • Like 1
Not all 3 inches are created equally
Moh are you running a cat...if so, ditch that...
Cooler piping and cooler is always an obvious one
Intake pipe sucking shut is never good
Sometimes the turbo you've chosen can have a restrictive exhaust housing particularly if it's a responsive turbo and gets choked up top
That power is plenty for the street, hit up E85 and be laughing
i do have a decat.
ill throw some intercooler hardpipes on this bitch when i can.
wouldnt be intake pipes, george is making about 400kw with stock intake pipes and cooler.
my problem is i dont want a cannon, and all the free flowing exhausts are cannons.
also will need cam gears, and may go for a set of cams while im there. because mohsen.
but most importantly, ill have to drive it for a bit and get used to it.
Don't understand why workshops if they say its an exhaust issue, just don't quickly test it by dropping the exhaust. (As long as the customer is happy to pay for the extra time)
Would suck for Moh and other customers if they bought a whole new exhaust system only to come back and have the exact same issues
i do have a decat.
You have 707160 -9s yeah?
Should make 300+ at 18 especially with rebuilt motor.
they didnt say it was exhaust, not sure whats up. the car has been an absolute bucket of shit.
my first build experience has been nothing but a nightmare.
just random shit that shouldnt have happened. eg: f**king vac leaks everywhere.
You did replace every vacuum hose on the engine while it was out though? Right?
Generally Fujitsubos have a narrowed down part of the piping just before the rear muffler to keep things quite despite being a 3" system, even their cannon systems have this
Also 2nd spot of the new falcon today (first on saturday night at ribs & burgers in Cragieburn)
Digging the bronze colour much more than the blue, looks more like a BA/BF shape again though
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
