Didn't realize you had a website scotty
Do you fit off the shelf exhausts? or not worth your time? (yes i'm lazy / don't have a hoist)
Of course. Most of them need customising to fit anyway. :P
spark breaking down at 20 psi?!?
thats terrible... whats the yaris setup rated too?
They have tested them to 800hp apparently and 40psi.
  • Like 1
Honestly I think Maltese take the cake for crazy chicks. It's like a whole new level of insane in the brain. As in, not just a stereotype, they are all batshit crazy.
As for both sexes on the whole though, I've met more insane Dutch people than any other nationality.
What is this food festival you speak of?
Also hows is the beemer treating you?
http://www.eventfinda.com.au/2014/3rd-annual-macedonian-food-festival/melbourne
Apparently there is a rival Macedonian festival being held in Williamstown on the same day. Should give you some insight into how bitchy they are lol
Car is going well, could do with a bit more powah / noise but that's not far away
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
