oh, youve upgraded. mashalah haha
Yeah like to mix it up.
What you driving these days bruv?
Sexy rangey
Had some initial issues with it, but now its good.
Thirstiest car I've owned to date though.
I bet! something tells me fuel prices aren't of concern though...
ive still got my r32 sedan, now with an rb26.
looking at buying something a little nicer and a little more plush for daily duties though.
Need some good army/war movies to watch... Shit like blackhawk down, zero dark thirty etc.
Go go go
Apocalypse Now, Saving Private Ryan is always fun, Full Metal Jacket, Jarhead, Platoon, Behind Enemy Lines
maco chicks. as crazy as they are made out to be?
discuss.
yes, well most are, one i dated was batshit crazy
Honestly I think Maltese take the cake for crazy chicks. It's like a whole new level of insane in the brain. As in, not just a stereotype, they are all batshit crazy.
As for both sexes on the whole though, I've met more insane Dutch people than any other nationality.
This
http://www.eventfinda.com.au/2014/3rd-annual-macedonian-food-festival/melbourne
Apparently there is a rival Macedonian festival being held in Williamstown on the same day. Should give you some insight into how bitchy they are lol
Car is going well, could do with a bit more powah / noise but that's not far away
Yeah has all the bureks bruhhh
Go go go
Get a 6 (???) part show called Generation Kill... Download it in 720p+ if you are able.
OoRar!
  • Like 1
OoRar!
Shall do
Seen em all apart from Apocalypse now, always thought that was some spacey movie...Will watch if it's not.
It blurs the lines between war and some spacey shit, but it's still very much a war movie and very violent
Some movie buff top bloke will say it has nothing to do with war and that it's about mankind and humanity
But it's war
Think I've seen The Sopranos start to finish at least 6 times, but I'm sure I'll watch it again
Watching The Devils Advocate at the moment...
Watched Seal Team Six - The Raid On Osama Bin Laden earlier.
Watched Sniper 1 and 2 last night...
And a Navy SEAL documentary this morning.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
