ok peeps
any recommended mods for evo
got enough power but keen to know of other recommendations?
want to get a new front carbon lip but need a place in AUS or someone that will ship? lancershop.com wont ship it to AU
hey hamish
seat brackets = very good mod, thanks for tip
ok peeps
hey hamish
Ditch the 4g for ej20t.
:P
silver s2 r33 about 30 mins ago
Cranbourne east maccas.
Rego SIF XXX
I was buying the wife a 1 dollar chocolate cone.
You where 4king 1st gear between speed bumps
Sau stickers in rear quarter glass, v35 wheels i think.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
