tyres for steerers.
what do you all rekon? while torching tyres is fun.
i got my hands (practically stole) on a pair of ad08rs to keep the rear planted
So... put some AD08R's on the front... Front grip is more important than rear grip... Unless you wanna understeer and make sweet love to armco
tyres for steerers.
What size?
Im trying to get rid of some Hankook Rs3's
How badly you trying to get rid of them
Depends how much your going to low ball me.
I don't mind getting rid of them, but not desperate. Know what I mean?
Thought about just wrapping them up and keeping them, but that also clogs up my garage
They are also currently on rims so i wont also need to pay to get them off em which is a pain :/
My R1Rs are wearing down but not dead yet so how much I low ball you depends on how much you high ball me
Didn't you have another set too?
I got 2 x brand new ones 265/40/18
and 2 x worn ones 265/40/18. I haven't measured the tread but maybe 60ish %?
Take the driftek rims with it and get the whole lot cheap cheap
wont be tracking it any time soon..
too much shit to pay for .
You really want me to give up my D1Rs for some cheap common wheels?
Will PM you about the tyres. Do you know what year of manufacture they are?
i just had an asian family walk into the store, and everyone had an aussie accent.
when i say aussie accent, i mean, like birds after hes had one too many vb's some pingers, a point of shard and a hoon around in a VN 5litre.
mind blown.
Pretty sure they are 2013 manufacturer. Probably mid?
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
