Try tucking elbows in and point the mirrors more inward too...it's odd because the more you point mirrors in, the more you will see of yourself in them, but it still gives you a better angle to view what is directly behind you - sort of quality over quantity. You don't really need mirrors anyway, just headcheck everything, it's the safest way IMO. Rubberneckin' baby.
Will give it a shot. Thanks schmate
Best way is just go fast enough you don't need to look behind
I don't think I've touched the road bike since I got the dirt bike #FIFO #needmalloo
Tyres down to the wires :( gonna need some new ones soon pretty sketchy in the wet today, think I'll just get some cheap shit
Time for fifo job?
That's a lot of track riding. I want to do CSS but they are pretty booked out for now. Gonna just wing it at a track day and prolly break some lap records if they're lucky #46
I've done like 8-9 track days so far between PI and Broadford... Wouldn't stress too much about not doing css straight away
also.
got a pair of used A050s.
f**k it, ill chuck em on.
cruised around for a bit. thought eh lets try do a skid.
tyres were like, nope.
such acceleration.
many push back
so bill cosby.
wow
  • Like 1
I have A048's on the evo, spinz up all 4. Should have stuck a 4g63 in Mo. :P
haha should be good once we work out why it keeps bitching out when we add more boost.
is e85 really worth it? i have to drive 15-20 mins to get it....
Not for now... It's pretty boring after riding track...
you should understand this Moh, It's like how you found vagina boring after riding cock
froff a good dicking.
Depends how many Jerrycans you can fit in the back seat if you are driving to Winton (20L) and Home (20L) and What you'll use on the track (60L)...
That said, its a 4 door, so heaps of room for jerries.
doitfgt
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
