Remember this up a driver dynamics run day
So they gotta pay for birds...
But in all seriousness they have pro drivers for driver training eg v8 super car drivers
much much less cars
So you get 20 min per hour
Much better than 3 sessions as wrx gave most of the day to the porka club
This
Having seen these days first hand, I would do one over regular track day anytime
So much more time on the track and spaced out
They do have some pretty well known V8 drivers there coaching; that's a pretty cool drawcard on it's own
I haven't flagged since I didn't turn up to the last one...completely forgot about it lol
Did a john bowe day as first track experience and it was good. Only downside was when something went wrong and lost 2.5 hours fixing it. Then you start counting the dollars.
Guy there who had a smooth day sandown) did around 50 laps
This
Did said DD day. Had v8 supercar driver take my car out to show me its potential. Was shitting bricks as it was sliding towards the wall. He cooked my brakes and rotors. Full brake rebuild. Deff would do again but with proper pads/rotors
  • Like 1
Sounds like he went a bit past it's potential
I'd be pretty pissed off if that happened to me lol
Thats the main thing I was laughing at, 20 minutes per hour with a bunch of cars which haven't ever been on a track before... They'll be driving hard and max out temps after 2 hotlaps.
HIGH possibility that they'll identify weaknesses in the car (as everyone does on the first 3-4 track days) or break something or even minor stuff like popping off cooler pipes due to sustained boost and heat. Std brakes/pads/oil cooler/ps boiling/tyres running out
Nek minit they've missed 3 sessions trying to repair a car in the pits and it's cost them $100 worth of the day.
Tell you what though, with the number of GTR's that are down there... Racepace should be there offering advice and guidance to them... So many potential new customers who are getting a taste of the track bug :D
Tbh, most of the guys that go down there are mx5 owners, M3-6 owners or s2000 owners with intake mods.
You get some amateur race teams trying to get some track time with added advice
Current entry list...
R33 GTR
Porsche
R34
R34 GTR
R34 GTR
R33 GTR
626 Coupe
Evo
BMW
R34 GTR
R33 GTR
86
M3 CSL
R34 GTR
Evo
R34 GTR
Subaru Liberty
Evo 6
TX3 4WD
S15
Evo
WRX
s2000
FPV GT
M3
I think I'm going to head down on the 4th to check it out... looks like there's going to be some decent meat there :)
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
