At least they took it before you spent the money at revzilla..
Too soon?
Never too soon.
Stolen from underground carpark in Boronia
Much like Ric's Skyline
how do u steal a bike?
srs
besides picking it up and chucking it on a ute
This is pretty much what they do.
I had a disc lock on it with an alarm and it has a steering lock too.
They would have had to remove the front wheel and lifted it up / dragged it out of there and wheeled up onto a ute or something.
Guessing they nicked it for parts.
Yes I'm insured.
Pull up at servo... Car in front is just past the pump, looks like they're leaving.. Starts to reverse past the pump towards me... I beep to notify them of my presence, as if it wasn't obvious enough already.... Continues to reverse until our bars become one.... Then does a runner...
Chased for about 5 minutes... Not an easy task keeping up with a ba falcon in am excel but I held my own. Lost them eventually.
Now they just better hope I don't see them again. 450mm shifter is hanging to tighten some nuts
Revzilla sell nuts
Did you get rego? Servo would have it on camera...make the fker give you a new bumper even if it's not damaged
My neighbour spotted 3 motorbikes hanging around our driveway at around 1pm today and some old guy talking on his phone in the carpark. Gotta be then. Fking flamin mongrel motorcyclists...so much for being something of a community.
The disc lock on the bike had an ear piercing alarm so I don't know how they pulled that off without anyone hearing. Must have been no one home in the complex.
So I have a time and a description, there's shops on the streets all near me so prolly CCTV that would have got three bikes riding along...I have a screwdriver left behind that could be finger printed by the cops if they decide to do some detective work, but let's face it they prolly won't bother over a theft :(
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
