House parties are the way to go, or in the loungeroom at home with a scotch and an ironic 45 on the decks you spun 10 years ago back when you were mainstream and uncool.
this any time.
think will drive up the country and have a few beers with my mates this year, shed party...
East west link would be alright, but using it to drive to my job where my hourly rate has just been cut in half, along with everything else they want to strip us of, not so much.
I didn't hear any of this from liberal ... Was this Union scaremongering?
This was my point.
Labor scaremongering would have you believe the Liberals will decimate the state like Skynet in The Terminator, where "big business" will destroy everyone but themselves
Liberal scaremongering would have you believe the Labor will decimate the state like the Tripods in War of the Worlds where "the unions" will destroy everyone but themselves
It's the same shit, just a different title.
I cant believe people actually fall for it.
anyone that voted for labor, just because they will scrap that tunnel is going to very disappoint.
as if a political party backed and controlled by unions is going to cancel a major construction project.
heres to the east west tunnel opening maybe 6 months later than it would have under the libs.
I suspect those people largely voted for the Greens... who continue to trumpet their own relevance despite holding probably 1 of the 88 seats in the lower house
dont get me started on those idiots.
f**k the people save the enviroment.
as liberals would not have had a delay..
oh wait I hear what about the nagambie bypass, delayed over a year...(sorry this was the most recent I could think of built in past 4 years)
built under the liberals.
burnley tunnel.
massive issues had to be closed and repaird
built under labour.
seriously they as bad as each other
  • Like 1
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
