If I was working in a high stress, high skill position and only getting paid $70k... I wouldn't getting out of bed every day to get threatened by junkies.
Response times are a joke, and there's nothing they can do about it without a budget.
Did smile when I spotted an ambulance yesterday with "Thank you Victoria!" written on the back window in their colourful writing :)
  • Like 1
Damn straight they earn it. Majorly shit job.
Agreed.
The main issue I have with all this is the wait times, I have been a paid up ambulance member all my life, if it took 30 minutes to get an ambulance to me in my one time of need I would be very pissed.
Bloody oath, I'm surprised your insurance company didn't waive it cause usually when you can identify the third party driver or in this case the thief, they can recoup funds from them and waive the excess.
Well they contacted me after they found him, invited to court but busy with work and shit. Basically filled out some thing and requested the thief pay the cost of excess, never heard anything else further though.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
