.. yet they are always the industries you hear about cuts being made in, whilst we continue to blow money on huge sporting events and luxuries etc.
because it sells. media control.
no one cares about some politician opening a new primary school in Woop Woop, people care that some politician cant throw a cricketball or being used as a scapegoat for some money pit.
holy crap.
Poor lady driving that thing, that would mess you up
Yeah I feel for her. Even if not her fault, you don't want to be involved in a fatal accident, not to mention the flashbacks to it happening.
I would feel even worse if thief sold bike to unsuspecting person who then crashed and died...
Number plate wasn't on the bike at the time so I daresay the rider had knowledge of it being stolen if not the thief himself
I'd like to know where his friends are who helped steal the thing and if cops have a way to find that out...doubt it though
Hmm.
from image and article.
he was traveling north on Stud rd.
that intersection did not ahve lights (from google maps.)
and the car was hit on the passenger side...
so looks like she was driving south and turned right into McFees rd.
so she cut him off.
but then you have no idea on speed he was doing nor if lights were working and such.
plus trees in center strip would not have helped view.
either way sucks to be her.
Wow this Vu v Ross Saga has gone to another level
Any lawyers want to chime in?
Can't saw Vu has done anything wrong, maybe defamation? But seems as though he only posted events on what had happened
10402031_10152854294770937_3693497857108
I get the dude stole the bike ... Callin karma cos he died seems a bit ott don't ya think? Thieving scum no doubt..
I don't wish death upon him, jail sure...but the kind of person who steals a bike is the kind to ride it like a moron, so in that case I say karma in a twisted way. The fker could have killed someone doing that so I'm glad he was stopped before he killed someone else and that he was the only life taken in the process.
I daresay he could give a fk what happened to me, and the reason he took my bike is cause he didn't. For all he knew I could have had finance on it and been left in debt with no collateral = fk my life.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
