Yes I noticed this
I keep forgetting the date it was stolen and focusing on the date it was found
cops should contact her and find out who his bike mates were etc.. but fat chance of police doing any actual work I guess
Actually she probably knows exactly who helped him steal the bike, I wonder if she'd give up the names given what's happened now..
Edited by UNR33L
Fat chance of her doing that
I'm guessing the acquaintances are keeping very quiet, probably even from family and friends
There's a few motorcyclists on his friends list, one rides a different model R1, one works at Peter Stevens in Dandenong, could have had a leg in it
If I was very wealthy I would buy it, put Toyota badges on it and track it.
Then I would collect all the 34R fanboy tears in a vial, put an atomizer on top and use it to mace their security guard at the next meet.
LMAO!
what if i told you, im looking into buying an R34 R.....
but only a bayside blue one on superlaps so i can join all the other bayside blue douche bag owners.
  • Like 1
Careful Leroy, a lot of those have conditions where you're only to drive to workshops and compliance / Vic Roads
yes im aware.
however i have the distinct advantage of having numberplates, so ill fit them to make it less... likely to be pulled over?
just need to figure out what screw size is required. i could never bloody figure it out on the pulsar
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
