Shure for earphones. I always thought sennheiser were a bit overpriced or over bassy. But still shit on Bose.
Start spending anything north of $200 for anything other than sound cancellation and MP3's dont so the headphones justice.
Their early work was a little too new wave for my tastes, but when Sports came out in '83, I think they really came into their own, commercially and artistically. The whole album has a clear, crisp sound, and a new sheen of consummate professionalism that really gives the songs a big boost. He's been compared to Elvis Costello, but I think Huey has a far more bitter, cynical sense of humor.
who needs a Mic? you just plug your headphones in the mic jack
I remember plugging microphones into headphone jacks when I was younger...you did get a tiny bit of sound out of them
Hey guys, had some problems with the Evo over the past few days... can I bounce some ideas off you to help diagnose?
2 days ago the head unit (Aftermarket JVC Double Din Touch screen) just went blank and restarted as I was driving home.
1 day ago on my 50 minute drive home it happened 3-4 times, most of the time after I'd been sitting at a set of lights for a while, literally the second I let out of clutch and started moving forwards. So at this point I was thinking "Maybe a loose power connection at the back of the head unit?", but it always started back up immediately by itself.
This morning I was cruising along eastlink at a hundred, Head unit went off like all the times before but when it started up (and was playing the radio just fine), but there was a message on the screen saying "Power off unit". A few seconds after I noticed that the engine gave a shudder and lost power for a split second, a few reds came on the dash (engine shutdown) and then it restarted itself with momentum and being in gear. The Check engine light stayed on until I pulled over, turned the car off and back on. Drove fine with no loss of power for the remaining 20 minutes of the drive.
Head unit went off once more when I was pulling into the carpark at work.
Thoughts?
if I mysteriously go missing from the forums you know the Evo blew up
Son of a bitch, you shouldn't have said that!
Thoughts?
first thought
bad earthing?
  • Like 1
Where though, and why has it popped up only in the past few days?
Engine bay has a full high quality earthing kit which connects about 10 different places together, inc the battery itself.
Think I'll dig up the multimeter here at work and check battery and alternator voltages, though that'd surely show up with the battery light on the dash.
Perhaps an arc from a short made the ECU temporarily confused, or read the CAS wrong, and that caused a misfire or shutdown?
inb4 "Oh it does that... one of the reasons I sold it"
  • Like 1
well... it's been nice chatting with you all these last 19,562 posts...
  • Like 2
bolts come loose, just start checking connections.
after that check connections and current on alternator
then battery test
def sounds electrical tho
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
