As it's a falcon, does it have all the mounting points already under the back end? So its just a bolt up kit and you just need to connect up a plug in the boot (could already be there?)
Its not like it's a "Weld xxx to subframe" job...
yeah its just an ebay kit.. bolt it up plug in and done I guess.. hardest part will probably be cutting a neat hole in my rear bar?
So senheiser is good? Buying a pair for the plane trip to/ from Thailand, was gonna go jb and try some on but was leaning towards senheiser momentum if they sound good as they don't look as terrible as half the others, and aren't apple beats
I've been running some HD515's here at work for about 3-4 years and they've been great... Only considering replacing them now because the foam is starting to collapse (you can buy the foam bits separately... but really I just want a new toy.
And yeah, bass is a little bit lacking... but honestly when I'm sitting at my desk in an open plan office I can't have them cranked too loud anyway or people will notice, they're open backed so a bit of sound comes out those slits as well
Just got back from lunch at southland, gotdayum some of the bitches there were vnice.
School holidays brah.
Also, whoever invented microsoft office protected view can die a painful desth
this is why I'm not stressed about the lack of bass in the wireless ones.
I originally bought them for home to watch TV when katie on Night shift.
sound was not up to it tho, transferred to work and prefect, isolate me enough and I can go to the printer and such without taking them off.
and they don't annoy others.
Ended up being a gigantic tightarse and bought these.
https://www.jbhifi.com.au/headphones-dj/headphones/sennheiser/sennheiser-mx-170-in-ear-stereo-headphones/64392/
Sound is nice and clear. Not tinny with super loud highs like some cheap earphones. mid range is good, bass is lacking as is to be expected overall though good for $20 and more than adequate for the one time in the foreseeable future I'm actually going to be using them.
Make sure you got the right thing to plug in I bought headphones nothin fancy like yall ballers but only had 1 jack but needed 2 for sound both ears else it was a bit dodgy.. That was on a380 not sure if it applies for all planes don't fly much ..
they should be fine
the in ear ones I have sound pretty good, and have survied being bashed around quite a lot:
https://www.jbhifi.com.au/headphones-dj/headphones/sennheiser/sennheiser-mm-30i-in-ear-headset/67504/
vast majority of plane have the dual plug (tho one of the cathay pacific ones I last week had normal..good sign)
so people don;t steal the headphones off the plane for home:
I just have some of these:
http://www.ebay.com.au/itm/3-5mm-to-2x3-5mm-Airplane-Travel-Headphone-Earphone-Audio-Jack-Adapter-Converter-/400818983844?pt=AU_Electronics_Portable_Audio_Accessories&hash=item5d52ac53a4
to convert, but buy a few as you always end up leaving them on the plane after a long flight.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
