All I'm hearing from people regarding times is "It was an untimed day"... as if they weren't running RaceChrono on their gold plated iPhone 8s 512gb
Though... I wouldn't be bragging about speed either if I was making 230kw on E85 out of an RB26...
  • Like 1
Haha they all had go pros. Mounted everywhere. Surely they know their times.
So I was taking a pic of moh and notice iron Mike had actually hired a model to take pictures on his car. At driver dynamics learning day.. a model.
So much gays
was this before or after moh ate her?
landed in melbourne on saturday to 40 degrees.
was quite bearable.
thanks cairns.
Bet it was better than when you were in Iraq, Afghanistan and Vietnam at the same time battling 4 armed mutant insurgents in 85deg heat doe
  • Like 2
The e85 monster was having its ass handed to it by an a45 amg
A45 AMG is pretty quick though!
In saying that 230kw on e85 on the r34GTR
Probably similar power to weight to the tuned stock turbo'd R34 GTT which makes 200rwkw at around 1,400kgs
But dat r34 gtr doe #race #rb26 #gloves #e85 #race day # race helmet #security guards #fastest car # most exclusive car
  • Like 4
I don't think there would be a huge demand for recriational travel to recent and current war zones
thats right, too many people been there before for you eh?
yeah not sure I would be following his advise..
your definitely not our demographic martin.
  • Like 2
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
