What sort of times and top speed do you get up to on your motorbike?
I've seen around 250 on my speedo down the front straight, I'll have GPS speed next time though so I'll get back to you after my trackday there on the 27th. Should be able to get more speed with my latest mods, but will be cloesr to topping out so it'll be interesting, hopefully doesn't hit the limiter down the straight.
Times, my best so far was a ~2:05 I think... I take a few seconds off every time I go usually, but obviously that'll slow down as I get under 2 minutes.. My quickest mate does a 1:40-1:41, another around the 1:47 mark and then a few in the 1:55 region...then a few slower than me and one around my pace, at Broadford at least..
Stock fuel lines are fine in skylines
Might not even need pump and injectors as your turbo is only small anyway
Currently have a Walbro 400L E85 Compatible pump, and 550cc injectors and new fuel line in the engine bay... I've heard that you should get the proper E85 line for inside the tank though, since the inside of most lines can handle it, but the rubber on the outside generally doesn't last when its submerged.
Chris made it make a happy 278rwkw on 98 (then pulled back for track safety), and then the intake manifold gasket pushing out the side made it want to detonate on the straights at Rexmas. So going to fix that up and chuck some E85 at it to see how it likes it, either the turbo will taper off or injectors will max out. Hoping for the magical 300 so I don't start breaking other things while I'm out there.
ouch. Why not throw in a remax steel while youre at it?
For the $330 for the gears + $400 for the pump I may as well just get a better pump. On top of that car needs to be done by the end of the week so couldn't wait around for the gears.
It'll be fine, N1's only really break if it's an aftermarket balancer, or you get really unlucky.
  • Like 1
250km/h is bloody quick!
A mate of mine just came back from PI; his first time there and second track day...lodged a 2:17 for the day. I imagine he'll be cutting off a few seconds ala dezz with the next visit. Jelly cause I was supposed to go with him :(
As for ethanol, all you need is a fuel pump and injectors that can deliver it fast enough, and a tune / whatever mods to support your power.
That's it. The rest is a wank. Uncomplicated science that people - usually those who aren't running the stuff - make into a big ol' Poirot murder mystery.
I'm all about that E85, 2 years now, no treble.
  • Like 2
Speedos lose their accuracy above a certain speed; it's unlikely anyone looking at a speedo 200+ down the main straight of PI is actually doing that speed. GPS only way to tell.
I think it's easier for cars to come out of that last sweeper onto the main straight with more speed already built up.
Plus 600s die in the ass above 200, top out around 260-270.
aye ric
http://www.ebay.com.au/itm/Vl-turbo-/141531162467?pt=AU_Cars&hash=item20f3ea2763
lets go halfies, slam it on its guts, with a fat as f**k dose, just cruise around and flutter bitches.
aye ric
That's quite nice.
I had the chance to put BioFuel lines in my car today with the engine out, opted not too because you're right, it's not needed!!
aye ric
Not gonna lie, it looks like my first car hnnngg..
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
