just bare in mind here fellas, the gps hardware shit you use on your phone, is a once calibrated piece of junk.
use a seperate designed for piece of equipmunk, and make sure its calibrated.
also, enviroment plays a huge part in gps signal. so dont just rely on that.
not saying whats above is wrong, just giving you all the info.
don;t use the gpn on the phone,
I use an external 10Hz GPS reciver liked to racechrono on android.
the lap times are withing .1 of a second of the track ones, (think it more due to the start stop line in racechrono is not the same as the beam they use for our track days)
so think the results are fairly accurate.
assumed that but thought would clarify.
when I used the GPS jsut on the phone times were more than a sec out from lap times, the external GPS as mentioned brought it down to sub .1 so I'm happy for the time being.
  • Like 1
If you need to be accurate to less than 1/10 of a second for recreational racing... you need to get a life lol
If you want an accurate representation of how well a different line through a corner effects your time, then having an accurate GPS is pretty important.
I use a 10Hz Bluetooth module as well, stuck to the top of my windscreen, because I have my phone wrapped up in my centre console and GPS Reception when you're inside a big metal cage isn't ideal.
Lap times can be within a 0.1 seconds... however things like top speeds and corner speeds go absolutely retarded if you've got a poor signal and it thinks your bouncing all over the track.
What if you drive a BNR34
Them you don't need to be timed as that is below you. You already know you are the fastest. Even faster than the RWD guys going faster than you
  • Like 1
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
