Wiped car out at 30kmh last time I went for a drive, haven't done any real spirited driving since..
Nurburgring tomorrow, what could possibly go wrong
add minus temps for extra grip...
what you hire?
remember it could be worse, friend rocked up only to find:
526746_10151506134974371_23351088_n.jpg?
so jumped a plane to Amsterdam for weekend instead
Just going with a Clio RS, would rather do more laps in a slower car than less laps in a faster car when the limit is the guy driving...
Been in Europe since Nov, so trip wouldn't be wasted if track not open this weekend.. Doesn't look like it's gonna snow, so most likely will be on for some 20 minute laps in the rain in pants shitting terror
if I can take a swift around in 10:17 in drizzle, you will be fine.
Festival Hall, Feb 2012
I recall. Monica
Beginning to think Dezz' memory ain't what it used to be
Also remember a truck trying to clean up Dezz in his Falcon and him chasing after the truck
XUX-799. My memory works great when revenge is involved
  • Like 1
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
