I don't remember meeting you mohsen, can't have left much of an impression.
And don't be ridiculous, no one would post for likes if you died.
I remember the meeting
Something about Mohsen getting his cousins and friends over the other side of the racetrack to beat up Dezz
Dezz saying he'll drop them after he drops Moh
Awkwardness for a couple of minutes
Then sunburn
rofl. and yeah, jonoe almost dying
pat, do not to 26.
it took me an hour to get the bottom afm pipe onto the afm.
to 25/30
dont be a bitch.
i dont remember meeting you at AS nickos.
but i do remember froffin your car on edgars road when i was a young thug muzzin my way through thommo (kid who peddaled everywhere because too young)
also, anyone missing a silver fiat punto?
why do i have people calling up and describing the item but not giving me the make and model number
"hi im calling about the dishwasher you have listed on your website under dishwashers, incase you forgot they wash dishes, are approx 700x700x1500mm in dimensions and resemble large rectangles, i would like a price on this piece of machinery" - exagheration
WHAT f**kING MAKE AND BRAND?
Spent the weekend on the skyrine...
Oil temp sensor installed with thanks to Scotty and his lathe / tapping skills.
Little coolant line that goes behind the block replaced (had previously split and been "fixed" with a straight barb because it was too hard to access)
Intake Middle Gasket replaced with Plazmaman replacement
Wideband gauge installed, still need to punch a hole in the floor with a rubber bung to run the sensor through to my front pipe
Then E85 Tune and Phillip Island on the 8th.
Everything is coming up milhouse!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
