I demand further clarification regarding this hollandaise of which you speak.
Didst thou purchase said hollandaise from ye olde supermarket like a common peasant or didst thou appease thine hollandaise gods and maketh same?
Ain't nobody got time for that when the egg cravings set in
REJUVENATION $1,000
Requires 2 days. Used for light swirl removal. Usually required for cars that haven't been into Final Inspection for one or two years.
The cheapest detail at Final Inspection is $1k?
Patricia?
Wow I'm planning to go there soon, maybe I need another $500 lol
dezz my car is going to final inspection in about a month
my quote was around that price, a few $ less which includes removing existing decals and fitting new decals as well
its a fair bit of labour to fully do a car, thats why its so high
just go down there and talk to them
you can im sure get a specific package for your car or bike or whatever etc
best recommendation is to go talk to them
my headlights are pretty icky so they will pull all the junk off them too
I go out for breakfast and order dishes with hollandaise which they make fresh, does that count as being home made?
Yes. As long as they make it from eggs, clarified butter vinegar etc... (not from powder, water and jism or whatever that fake shit has in it)
REJUVENATION $1,000
Patricia?
FARKEN LOL
spends a grand on a skyline worth about 2.... multiple times
you disgust me
CONCOURS $18,800
Requires 1-2 weeks. As it has been since the service was introduced in 2008, this is the world's best car detail, no compromises.
Final Inspection will transport Damian Angelucci plus assitant to wherever your pride and joy exists in the world to provide this service.
Service cost includes all travel, taxes, materials.
That's probably what paddy gets on his $2k skyline
  • Like 1
wtf.
really, you cant make a shit shine like gold. if its crap or old paint, it will never be the worlds best car detail. do you pay them to come over and say "well theres ya problem. sorry, we're not miracle workers"
wtf.
we know... Pat's been trying for years lol
Honestly can't believe how many cars get overtaken in my vid above... most people seemed to be rolling along at about 90, sometimes 100 in the right lane...
Damn Sunday drivers, at least most of them understood what to do when an aggressive looking car comes up behind them in the right lane
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
