whats wrong with current lip? repair it?
i'd suggest trying to stick with plastic, the thing will get a clobbering - carbon fiber and fiberglass will just crack.
I left it in Canberra
It was pretty scratched / crapped anyway
Birds when are you dropping the car off at Racepace?
As soon as I can lol
Was supposed to be next Monday but just saw email from Chris saying it'll have to be later in the week cause of PI catch up
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
