There is a market, but I'd be worried it will die soon.
R35 GTR price keeps dropping and 34R's are only getting older.
Spend $60k and own it for 2 years as a weekender, drive it a handful of times and all it for $30k does not sound appealing to me. I might buy one after the drop.
yeah that is true 35s are under 100k but I think they are a different proposition got very high maintenance costs .. Not that a 34 won't cost money but the 35s got a lot of stuff that can go wrong and cost big $$$
Eh maybe I'll try find a 180sx to trash around a track in lol
Fark that would be a fun car
And Narva headlights on the front :thumbsup:
I'm a fanboy of these:
http://carsales.mobi/cars/details/1964-Sunbeam-Alpine-GT-Series-IV/SSE-AD-3191987
But getting rarer and rarer to find. Would probably do a half assed restoration. Bolt on flares, big wheels, efi V8. All the oldies would be disgusted
Is cool, needs more Renault less Sunbeam doe :P
4K, pointless at this stage
3D, pointless since they were launched like 5 years back
65"... unless you've got a big room, the 480p/720p/1080p content you'll be playing on it will not be as sharp as it should be.
Would still bang, but not for that price
For the difference in price, I'd be going for this... then upgrading in a few years to a good TV once 4K porn is actually available
https://www.kogan.com/au/buy/kogan-50-led-tv-full-hd-za/
Yep.. and with aussie internet speeds the way they are going to be a long time before 4k is viable (depends on area I guess)
Our free to air only just got 1080i on a few channels heh.
Only reason you'd get a 4k TV is if you had a massive collection of stored 4k blurays or something
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
