The heat / rain / RDO stuff is fair. Helps that I like you though..
I wonder how many of those people sacked face that outcome because the employer can't afford the wages that result from union bully tactics (or if they are genuine flogs who hide behind the union and try to blend in with the decent blokes like dezz)
Considering what our companies charge us out at, I don't think it's an issue. People get hired and fired with the rise and fall in work. It's the nature of the industry, the union doesn't stop it happening, they can't, they just see that the proper notice is given etc
For example, at the moment Downer and Stowe have the lionshare of the work...Their guys get paid the same we do obviously.
My company has most of the work at the airport, but those jobs are expected to finish mid year. Obviously there's always more work to be won at the airport, but it's not a given that the contractor their currently will get the next job...
As my companies jobs finish, and if they don't win some more to keep the current amount of sparkies on the books, people will be made redundant (around 100 have already been made redundant in the 3.5 years I've been there) Some get re-hired, some are no good and don't come back, and others were just unlucky to be the one to go, and will more than likely get a job with whoever has most of the work at the time.
It's pretty rare that someone in my industry works for one company their whole career
So I thought I might do some trolling in the news.com.au facebook site to keep the left/right balance... Holy shit! I couldn't bring myself to reply to the epic stupid... ALL OF THE STUPID.
Admittedly I jumped into the deep end by going for an article about the Bali 2, but I thought it would be at least in actual English...
Never before have I seen the word "use" (meaning for some reason the plural of you) written so frequently... Not to mention "U" and "R" etc etc.
The pointlessly vitriolic commenters and holier than thou Internet tough guy's were virtually the only commenters with a reasonable point either for our against being made maybe once per 10 replies.
It was just bogan australia at it's worst... The kind of people that treat ACA as a reputable news source.
I thought the age was bad...
It made the age comments seem like a freaking pulitzer prize contest!
When you consider this is who they aim their articles at... well you know where I'm going with this...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
