Never understood the point of noise cancelling headphones...isn't this what the volume control is for?
loud volume is not ideal for long wear, I use them on flights to remove noise of engines to sleep.
and in data centers so the annoying whir of the fans does not give me a headache. (yet can still hear people talking to me)
they are a very niche market, and I wear my non NC more than them, but for the purpose they are great.
Yeah i've got active noise cancelling headphones, it definitely blocks out noise on flights and that's about the only time I use them
Too bad they're the beats ones but they were basically free so meh. Will use em for a bit before getting new ones.
this.
my favourite part of the article: it used to be ok to drink 6 cups or coffee/tea a day.
its true though that recent studies have shown sugar to have a larger affect on general unhealthiness than fats. and ive always preached brown/black bread is the only way to go. f**k those white loaves. #breadracism
Is sugar unhealthy though?
I would say people blame sugar for health issues/obesity as it is easy to go into a caloric surplus if you eat lots of sugary foods such as candy/chocolate/ice cream
Sugar is in fruit the only difference is that it contains fiber and micronutrients
  • Like 1
Sugar is great for a workout at the gym but most people don't use it that way
Too much protein can make you fat too
People like these gossipy new diet rules because it's easier to subscribe to bullshit theory and generalisation than it is to do hard work
I eat white bread, 2 eggs everyday, mercury laden tuna everyday, fast food every second day, butter, full cream milk, bags of potato chips, chocolate, heaps of red meats / steaks, loads of pasta and cheese, sauces and white rice...and fat fgts still wanna blame my ability to so this on a fast metabolism lol
  • Like 1
yep, better off finding what works for you
i personally dont care about protein carb and fat intake but sugar intake I somewhat take care of.. yeh I enjoy the occasional coke but not every night.
Edited by UNR33L
oh noes white bread, pasta and rice
Shoulda gone racist like the article and gone wholemeal brown
Ah, there you go.
Yeh cos banks have to get two sworn Val's if they can't get that they have a fall back price if they can't get that they have to sometimes go back to court to get it reduced to demonstrate they haven't ripped off the mortgage holder and done everything they can do get top dollar.
meh, just go to gym and eat what ever the hell you wanna eat :yes:
if anyone asks, you're bulking
Good work Leigh. Great size. Look thick. Solid. Tight. Keep us all posted on your continued progress with any new progress pics or vid clips. Show us what you got man. Wanna see how freakin' huge, solid, thick and tight you can get.
There are certain types of service that require notices to be affixed however this is not the norm. Banks have a public image to upgold so big signs are not usually employed.
As al said there is a lot f regulation aswell
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
