http://www.flightcentre.com.au/travel-news/travel-news/qantas-lounges-sloppy-dressers/?utm_source=twitter&utm_medium=post-blog&utm_campaign=february-blog&utm_content=qantas-lounges-sloppy-dressers
Gonna be some pissed off bogans at the FIFO lounge lol
Queue "what ya f**kin mean a bintang singlet's not f**kin appropriate mate?"
lol I hope this doesn't apply to work gear as I will be flying from Mines -> Melb :wacko:
#FIFO
Of course it does. I'd imagine thats pretty much exactly what it applies to
considering the Managers, GM's & MD's all wear work gear it would be pretty funny if they get bumped back to make way for a glorified pa wearing Target slacks.
is there time to change before bus leaves/at airport/at camp?
#FIFO
nope high viz clothing is allowed as it deemed a uniform.
which is funny
as the complaints were from the suits about the high vis clothing in the lounges.
I seriously don't see an issue about it, it's somewhere to kill an hour prior to a flight that they happen to have some free snacks and booze,
who cares what people wear.
which is funny
People with class
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
