Currently in the Gloria I wind down front Windows rain hail or shine if I see a copper lol
At a VIP last night and pretty jelly of some of the airbag setups. Raising height from their keys in an instant
House hunting update.
Been priced out by boat-shoe wearing 50yr old investors.
I've come up with my own cycle theory.
Young people rent in city, they then buy house in outer-suburbs. Once older they use equity to purchase investment property in city to rent to young people.
Time to increase my limit & fight these f**kers.
My brother has volunteered his house for a lan. Located cockatoo. Interested?
That sounds and looks on google maps further away than it actually is
Half hour drive for me with some mountain twisties on the way
better question, who the f**k faxes anything these days?
I havn;t faxed something since this guy was probably born
Government agencies and banks... trust me :/
Troll dad
Also, get out of RacePace I need that spot
what's the point, you are only going to get bumped when snowy wants a new sticker put on his car anyway :P
Chris did offer to do engine out and cover tow back to my place for me but I can't store a rolling chassis :(
And he can?
Last time I was there it was chocka block full of cars, every spot inside taken overnight... Borci has to do a big car shuffle every morning and night as it is :P Now you're going to make him push around a roller as well, brilliant :D
anything that keeps him away from spark plug installation has to be a bonus tho right?
And he can?
Never said he could...hence I'm on a waiting list for a dead car spot. I'm pretty understanding of their existing work situation hence have been patient. Just a shitty situation cause I do want to start on it soon, let alone the time it'll be in there for, because I don't believe in rushing workshops to do work either.
At your leisure car / engine builds probably are the best quality, compared to a rushed job... however I've seen too many people go that route expecting it to be cheap... but then it ends up being at the back of the workshop covered in dust for 12 months
How much power you running?
May have to swap for -5s, but I love response and will take it over outright power any day
Also winning is winning haha
335kw atm, would like more but this is just a track tune, it's nothing to laugh at, but I'm very used to it and bored already.
Snowy doesn't have a GTR anymore, he's got that Gemballa or whatever now
This makes zero sense Plats.
joeyjoejoejuniorshabadoo, on 02 Mar 2015 - 10:39 PM, said:snapback.png
Racepace use BKR plugs over BCPR or that your choice?
You might be right, truth be told it was just what came off the top of my head. Now I'm not sure which one. Regardless though whichever one it is its worked on countless cars so it SHOULD be fine in mine, it's the right plug for RB and E85 anyway..
:woot::whistling::domokun:
I'm a mechanic not a parts salesman u doofus
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
