I remember years ago standing in Chapel St, overhearing some wogboy talk about his VL turbo...no shit, I heard the words "stage 4 blow off valve" come out of his mouth
  • Like 1
Yo, where my Jerrycans at?
I got home with the fuel guage sitting right on E, and 1/2 a jerry in reserve. Perfect.
I'm still not sure how I'm going to get them back to you.
We filled my car Friday night and it got home on just over half a tank so pretty happy with that.
whos doing wtac this year?
Me, attending not racing.
Does it make the noise in all except 4th or in all gears?
With the clutch in / clutch out?
Can't remember to be honest, pretty sure it's all gears.
Clutch out.
Damn, I think I went through about 45L getting home :/ Cruising off boost (but I guess the intake leak would have made it richer than normal)... However, it used over 40L for 240km on the way up as well.
40 / 2.4 = 16.6L/100k (mostly off boost, but a few little squirts)
No rush on the Jerries, won't need them all for a while (until the next long distance track).
Where do you live again? I'm in Vermont, work in Cheltenham
Mine wasn't too much different then, probably around 40L for 220km.
I'm on the other side, Altona Meadows/Maidstone so not a quick trip.
I'll organise to get them to you at the next meet hopefully or sort something else out.
Clutch out.
If all gears and does it when sitting there in neutral with the clutch out, could be input shaft / throw out bearing or yes, spigot.
If it does it in neutral, find out if the sound changes (louder, higher pitch) as you rev the engine...if so, then it's most likely the above. If it doesn't do it in neutral and the sound doesn't change with engine rpm then it will be output shaft or a diff.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
