I like these:
http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1899
What's the price look like for you guys, what would you pay..?
Also.. Is it possible to shave a couple of mm off a wheel to make it a few mm higher in offset?.. Sounds dodgey but dem rears will poke out hard and I want to run big tyres.
Edited by UNR33L
Dude with a gun & no will to live has no relevance to a billionaires life
But sometimes a lot of relevance to his death
http://www.dailyfinance.com/2010/06/22/bad-fortune-five-bizarre-billionaire-murders/
I like these:
Hamish will tell you to harden the fk up, particularly as they are professors
i was considering shaving off offset... bad idea. you're not shaving off offset, you're removing meat that sits on the hub/wheel studs.
just roll guards/sort out suspension, fit tyres that fit etc. you'll be fine
I like these:
Harden the fk up
Especially as they are professors
D1Rs come in all sizes and offsets
Yeah but only one magnitude of gay
Lee even like 2-4mm would f**k it you think?
Birds d1rs in 20s look sheit!
Lol
Sif 2-4mm will make a difference fgt
That will get you 1 tyre size up which you will never notice.
4mm would be acheived with a guard roller and about 2.3 seconds
Lol.
Aaron has already rolled them for me, maybe I'll go down to import monster one day and try them on..
You had professors? thought you were rocking varrstoens
I want to at least fit some 265s f**k those 225s and 235s what am I gonna do with those lol
Edited by UNR33L
Engine build complete after many dramas.
'greg can you come here and tune the start'
Rock up with laptop
Play with ECU
car starts... and appears to run/idle fine/way smoother than it did before it died, no smoke, no leaks, just... purring away
f**k, expect 7 years of bad luck now everyone
I'm sorry
D1Rs birds?
11025186_690767431046669_180923112286857
That actually looks pretty tough.
People may diss them, but they are lightweight, cheap and can take a beating. Break or rash one and $250 to replace.
Lol.
You want to shave 2-4mm
Thats going to be the difference between a 255 and a 265.
Or a 235 and a 245
Etc etc etc
What on earth makes you think shaving 2-4mm will allow an extra 20mm?
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
