I like these:
http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1899
What's the price look like for you guys, what would you pay..?
Also.. Is it possible to shave a couple of mm off a wheel to make it a few mm higher in offset?.. Sounds dodgey but dem rears will poke out hard and I want to run big tyres.
Edited by UNR33L
Dude with a gun & no will to live has no relevance to a billionaires life
But sometimes a lot of relevance to his death
http://www.dailyfinance.com/2010/06/22/bad-fortune-five-bizarre-billionaire-murders/
I like these:
Hamish will tell you to harden the fk up, particularly as they are professors
i was considering shaving off offset... bad idea. you're not shaving off offset, you're removing meat that sits on the hub/wheel studs.
just roll guards/sort out suspension, fit tyres that fit etc. you'll be fine
I like these:
Harden the fk up
Especially as they are professors
D1Rs come in all sizes and offsets
Yeah but only one magnitude of gay
Lee even like 2-4mm would f**k it you think?
Birds d1rs in 20s look sheit!
Lol
Sif 2-4mm will make a difference fgt
That will get you 1 tyre size up which you will never notice.
4mm would be acheived with a guard roller and about 2.3 seconds
Lol.
Aaron has already rolled them for me, maybe I'll go down to import monster one day and try them on..
You had professors? thought you were rocking varrstoens
I want to at least fit some 265s f**k those 225s and 235s what am I gonna do with those lol
Edited by UNR33L
Engine build complete after many dramas.
'greg can you come here and tune the start'
Rock up with laptop
Play with ECU
car starts... and appears to run/idle fine/way smoother than it did before it died, no smoke, no leaks, just... purring away
f**k, expect 7 years of bad luck now everyone
I'm sorry
D1Rs birds?
11025186_690767431046669_180923112286857
That actually looks pretty tough.
People may diss them, but they are lightweight, cheap and can take a beating. Break or rash one and $250 to replace.
Lol.
You want to shave 2-4mm
Thats going to be the difference between a 255 and a 265.
Or a 235 and a 245
Etc etc etc
What on earth makes you think shaving 2-4mm will allow an extra 20mm?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
