I like these:
http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1899
What's the price look like for you guys, what would you pay..?
Also.. Is it possible to shave a couple of mm off a wheel to make it a few mm higher in offset?.. Sounds dodgey but dem rears will poke out hard and I want to run big tyres.
Edited by UNR33L
Dude with a gun & no will to live has no relevance to a billionaires life
But sometimes a lot of relevance to his death
http://www.dailyfinance.com/2010/06/22/bad-fortune-five-bizarre-billionaire-murders/
I like these:
Hamish will tell you to harden the fk up, particularly as they are professors
i was considering shaving off offset... bad idea. you're not shaving off offset, you're removing meat that sits on the hub/wheel studs.
just roll guards/sort out suspension, fit tyres that fit etc. you'll be fine
I like these:
Harden the fk up
Especially as they are professors
D1Rs come in all sizes and offsets
Yeah but only one magnitude of gay
Lee even like 2-4mm would f**k it you think?
Birds d1rs in 20s look sheit!
Lol
Sif 2-4mm will make a difference fgt
That will get you 1 tyre size up which you will never notice.
4mm would be acheived with a guard roller and about 2.3 seconds
Lol.
Aaron has already rolled them for me, maybe I'll go down to import monster one day and try them on..
You had professors? thought you were rocking varrstoens
I want to at least fit some 265s f**k those 225s and 235s what am I gonna do with those lol
Edited by UNR33L
Engine build complete after many dramas.
'greg can you come here and tune the start'
Rock up with laptop
Play with ECU
car starts... and appears to run/idle fine/way smoother than it did before it died, no smoke, no leaks, just... purring away
f**k, expect 7 years of bad luck now everyone
I'm sorry
D1Rs birds?
11025186_690767431046669_180923112286857
That actually looks pretty tough.
People may diss them, but they are lightweight, cheap and can take a beating. Break or rash one and $250 to replace.
Lol.
You want to shave 2-4mm
Thats going to be the difference between a 255 and a 265.
Or a 235 and a 245
Etc etc etc
What on earth makes you think shaving 2-4mm will allow an extra 20mm?
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
