^^^ Corporate first world problems.
vvv Fifo first world problems.
Welcome to the Pilbara...
Seen so many in our backyard in Wickham.
Is that a python? or brown?
Looks too big for a whip
Edited by L33SH
Pretty sure you said this in bed the other night
  • Like 1
Because 34 owner
http://www.sau.com.au/forums/topic/455094-for-sale-1999-bnr34-gtr-v-spec-n1
lol'd at sourcing lubricants from Japan
lol.
doesnt come with those painted sideskirts that every other 34GTR has. wouldnotbuy
i have a nismo radiator cap and nismo oil filler cap. maybe he'll buy them off me for a lot of money. #wank
damn all these plane crashes are starting to bug me a bit.
Why, it's not like you fly alo.......
nevermind
You firstly edited this post, then you had to look up these lyrics to write the modified post.
I know all your secrets.
that's a low blow man.... low blow
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
