Had foxtel installed today....sound isn't coming out in 5.1 for some reason... Anyone know why?
foxtel box is connected to the receiver via HDMI cable, receiver is connected to the TV via HDMI... Don't see a reason why it shouldn't work as everything else connected to the receiver is in 5.1....
Make sure that your Foxtel Settings are set to output sound in the proper format for the receiver to accept (maybe AC3 or similar), also make sure that the receiver is set to do Virtual Surround if it does happen to only receive a 2.0 or 2.1 signal from foxtel.
  • Like 1
Haven't even looked into settings yet, just assumed it'd work by default like everything else.
I'll sus it out now
Audio options available are
SPDIF digital audio output - AC3/MPEG
SPDIF digital audio delay
SPDIF digital audio attenuation
HDMI digital output - AC3/MPEG
Guessing it's something to do with the first or last options, but I set them both to AC3 and both to MPEG and nothing changed audio wise
SPDIF is if you're connecting up to your receiver using an Optical Audio Cable
HDMI is obviously if you're connecting it with your HDMI cable, so choose that bad boy...
Then you switch to the receiver settings for that input source and make sure it is set to expand out to 5.1 surround if it's only receiving a basic 2.1 signal as an input. Often you can hit an info button on the reciever remote and it'll show you info about what kind of stream is coming from foxtel
I opened an on screen receiver menu, selected 'sound program' then chose 'SURROUND DECODER', instead of the 'STRAIGHT' it was set to.
Seems to be sending sound through all 5 speakers now, just not sure if it's sounding how it should sound...I'll keep playing around with the settings...
The majority of Foxtel is in 2.0 isn't it except for some of the HD channels if you're lucky.
Yeah looks like it... I've got the HD package so not sure how many channels aren't HD, but the receiver seemed to be able to output in 5.1 last night...
Pretty poor that it's not all 5.1 from foxtel
lol
Also while we are on MP's mannerism's, I was listening to JJJ on the way home (weird huh) and they were interviewing Dan Andrews...
What finishing school did he go to again?
  • Like 1
Only selected channels and programs play in 5.1 so the majority of the time it will be in stereo.
If you want to watch stuff with 5.1 sound just download it. It's cheaper and is generally better quality haha. One of the reasons I don't have Foxtel even though I can get it for nothing.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
