i'm going to take a wild stab that the kind of lowlife scumbag that jockeys a speed camera isn't going to have much of a sence of humor
I believe to the contrary given they think it counts as a job
i expected better from rowville...
they must have gotten lost and thought they were in patterson lakes.
my view of rowville was never particularly tainted. i just assumed the dero's all hang out at knox shopping centre.
the person who stabbed someone at stud park the other week was from western suburbs i think.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
