shit did you crash a carerra GT?
lol naw
They stuffed up my popcorn and drink which was mighty disappointing given the uber inflated charges in gold class. You thought getting a drink in a bar was expensive bloody $17-$20 in gold class :/
lol naw
what was the drink?
serious: anyone here shoot?
was in mount dissa on sunday night camping with some of the boys, and we could hear deer calling to each other.
the only time we didnt bring the equipment, there are deer.
used to do quite a bit.
firstly on the farm so pests like foxes rabbits and some pest birds.
then moved into target shooting at uni so did that 5-6 years.
was discussing getting my license again (had let it expire) and getting back into a bit of shooting over the weekend.
its hard work, only thing ive managed to get are rabbits and feral cats and shit.
they could hear you and your mates coming from miles away...
Because I'd kill you if you shot animals
Kill a person for killing an animal. Logic.
  • Like 4
had my first bad fuel experience over the week end.
it was terrible.
how are we all? whats new?
What happened? I got a bad batch once, filled my tank with a grit which killed 3 fuel pumps before I rage quit and swapped to a different tank. Still have the old one in my garage and can't get rid of it, even for free on Drift Sales
